Home › Forums › Products › Plug-Ins › H3000 Factory — False Advertising › Reply To: H3000 Factory — False Advertising
June 25, 2015 at 7:36 am
#139444
H3000 is crashing Cubase 8.0.20. Actually it’s not crashing but when I have a semi-large project going the plugin works but if I close the project and open it again Cubase will crash. I’ve tried with restarts, cold starts but always the same issue. All that works is to remove the H3000 from the plugins folder, open the project again, then remove the h3000 from the insert. Then, if I need to use the plugin, I have to put the plugin dll back into the plugin folder, start again, then re-insert the plugin. Of course the next time I start the project it will crash again. This is lame.
