Home Forums Products Stompboxes Upcoming overdrive / distortion algorithms Reply To: Upcoming overdrive / distortion algorithms
#139674
Adamixoye
    2 things:
    – output of crushstation doesn’t seem to match output of other FXs available in H9 max, I have to boost output with “output level” control in crushstation up to 9db to match other FXs
    – maybe it’s just my unit, but I experienced weird behavior while testing crushstation – something like light clip with crack noise when I touched strings, occured only on attack of the played note – I had to switch back and forth to other algo and back to crushstation. disappeared for now when I rebooted H9.
    I experienced these same two issues.  Any advice?  The “attack” issue did seem to be related to the pre-sustain.
    Is there a good description of the controls somewhere?
