Home › Forums › Products › Stompboxes › More H9 Midi Clock Problems › Reply To: More H9 Midi Clock Problems
October 16, 2015 at 5:58 pm
#141085
gkellum
Well, generally speaking, you should be able to do this. I just hooked up a TimeFactor to an H9 running the latest firmware, and the H9 was following the TimeFactor's tempo correctly:
https://dl.dropboxusercontent.com/u/1383432/MidiClock.MOV
Could you try hooking up just your two H9s directly — configuring the first H9 to transmit MIDI Clock and the second H9 to receive MIDI Clock — to see if you can get the second H9 to follow the tempo of the first one?
