Home Forums Products Stompboxes Feedback loop possibly a cross talk issue Reply To: Feedback loop possibly a cross talk issue
#141860
thomashowardueae
Hi guys i have set the h9 up in pre post mode for a wet dry amp set up. which works fine so far.. i just have to set the wet to 100.
I would assume this works the same in a fx loop.
Im just wondering what application might i need to use wet dry mode? Is there still an issue with the pedal? Am i able to set up a scenario where i can test this mode correctly??
My rigs change depending on the tour and wouldnt want it to become a future problem.
Cheers.
