Home › Forums › Products › Stompboxes › No audio output when switching from bypass to active. › Reply To: No audio output when switching from bypass to active.
Hi Nick, thanks for getting back to me. I have tried resetting the H9 and only turned on the midi settings that I require but it's still doing the same thing. The other patches on my Helix don't have any midi comands to the H9, could this possibly be the problem? If it is I'll go through all the patches and put the commands in.
I have no idea what is happening, so can't be of much help. That aside:
One question – when it is in this state, does it seem as if the correct preset is loaded ? Can you adjust parameters, etc.
A second thing to try – when it is in this state, connect it guitar-H9-amp, and see if the same happens.
