Home Forums Products Stompboxes H9 inputs clip when in FX loop of amp Reply To: H9 inputs clip when in FX loop of amp
#141910
stilllife
I would have bought an H9 by now but I came across this line level issue.  I want to know if I can use the H9 with my rig.  I am DAW based, and would like know in advance that I can run line outs from a Kronos, Analog Keys, and Minibrute into the H9 directly, and output the H9 to my DAW.  My DAW outputs to active monitors.
While you say the H9 should be used only with instrument level devices, others say your documentation states it can successfully work with line level devices like synths.
So, will it work sans clipping in my setup?
