Home › Forums › Products › Stompboxes › A shame you can’t stack/combine Algorithms! › Reply To: A shame you can’t stack/combine Algorithms!
December 29, 2015 at 8:34 am
#141962
Styrioci
MrT wrote:
Meaning I run a midi controller so I can access 10 presets easily. How does that work with 2 H9’s? Would you need a seperate midi controller for the other one?
not at all, you can program H9 to listen on another MIDI channel, or create your own midi maps, so by calling preset 1 on MIDI channel 1 for example you need to save presets on 1st positions you want to run on both H9s at the same time and configure H9s to listen on MIDI channel 1.
