Home Forums Products Stompboxes A shame you can’t stack/combine Algorithms! Reply To: A shame you can’t stack/combine Algorithms!
#142031
jfzander
styrioci wrote:
MrT wrote:
Meaning I run a midi controller so I can access 10 presets easily. How does that work with 2 H9’s? Would you need a seperate midi controller for the other one?
not at all, you can program H9 to listen on another MIDI channel, or create your own midi maps, so by calling preset 1 on MIDI channel 1 for example you need to save presets on 1st positions you want to run on both H9s at the same time and configure H9s to listen on MIDI channel 1.
Do I need a MIdi Controller at all if I only have H9’s in my midi chain? Can’t the first H9 serve as a controller for the others?
