Home Forums Products Plug-Ins H3000 file locations? Reply To: H3000 file locations?
#142067
TLTD
gkellum wrote:
tfelts wrote:
I have it installed and authorized, but it is not showing up as a vst in reaper.  Where does the installer put the file(s)?  I would like to add the file path to the prefs in Reaper so that it scans the dir.
You mean on Windows I’m guessing.  I believe it puts it under Program Files/Common Files/VST, but if you relaunch the installer, it will show you where it’s installing to.
Had to do this so Sonar X3 would find Anthology X vst plugins also, thanks. I don’t know why the installers show one location (program files/steinberg/vst2), and they end up there. Wasted some time I could’ve been using the plugins today.
