Home › Forums › Products › Stompboxes › Expression pedal to H9 › Reply To: Expression pedal to H9
January 9, 2016 at 12:51 am
#142100
rsvmark
spaceJam wrote:
OK found the thread.
And yes, calibrate the expression pedal, use a TRS cable and make sure the knob on the left side is set to off position (full counterclockwise).
Thanks spacejam so that’s a TRS to trs? I tried re calibrating the pedal but didn’t work. Probably did it wrong- is there a thread somewhere that shows it step by step?
Final question – so does your set up have an aux pedal footswitch to switch presets? If so,
