Home › Forums › Products › Rackmount › Pitch correcting voice input to Midi key pitch › Reply To: Pitch correcting voice input to Midi key pitch
January 12, 2016 at 12:52 pm
#142126
MFPhouse
SkyWriter wrote:
The real question is: can I run VSIG in a virtual machine under virtual box,
Yes you can. !
It runs fantastic here. I have running LogicAudio in Backround ( reatime !) at the same time, while Vsig sending and received Data to/from H8000fw.
Also the other Projekt ” Voice to Midi ” V-Versa is no Problem on H8000fw. You have to learn Vsig – It´s not an environment for “On the Fly”. There are many possibilities to create your Stuff.
Good Luck !
