Home › Forums › Products › Stompboxes › H9 and a modfactor living together on the board › Reply To: H9 and a modfactor living together on the board
January 18, 2016 at 10:43 pm
#142196
gkellum
Trendin wrote:
I was thinking of getting an H9 MAX for some time now. Is it possible to connect the H9 via bluetooth and the modfactor via usb to the same pc without problems in the H9 control app?
I read somewhere on the forum here that the QA here didnt test it. So, will they work? will i be able to control both unit from my pc?
Yes, this works fine. You should be able to control both units normally from your PC.
