Home › Forums › Products › Stompboxes › Timefactor effect stop working › Reply To: Timefactor effect stop working
January 23, 2016 at 11:21 am
#142248
Hello
I have a similar problem with mine . After the last firmware update the effect now doesn't work: the switch"activate"doesn't active the delay and the led upon it doesn't work too. I can switch banks, but when I press the "activate" button (Left buttom) it doesn' t work, I can't select the preset and the led upon it dosn't work either. I believe It is not a hardware problem , because it started after the last update. When I am in manualmode the middle and right switch work perfectly, but the left one still inoperate. What is happening?
Hope you can help me tranks
