Home › Forums › Products › Stompboxes › SpaceTime Continuum [Preset List – 30] › Reply To: SpaceTime Continuum [Preset List – 30]
Brock, thanks for the tip on Hotswitch programming. I am still not getting changes in Hotswitch settings to stick when I save the preset after altering parameters with the Hotswitch engaged, usually only one that I have set stays and the rest revert to their factory setting. Unfortunately, I have mostly given up on the Hotswitch feature, although it is extremely useful when working correctly as your many presets demonstrate, as I can never get it to be consistent and lock in all the parameter changes I want. I will try the “blank slate” preset approach and see if that helps as I have always started by altering an existing preset. Still going through and testing your SpaceTime Continuum presets, lots of great sound effects and concepts to build on there. Quite an addition to the already impressive library of H9 presets!
