Home › Forums › Products › Stompboxes › No SpaceTime › Reply To: No SpaceTime
February 8, 2016 at 7:03 pm
#142485
gkellum
Ripprock wrote:
Keeps saying that SpaceTime is not compatible with the pedal,please upgrade the software in your H9. Does anyone have a fix for this.
When you click on the Pedal button in the bottom menubar of H9 Control to go into Pedal Settings, it shows the version number of the software currently installed on your H9 in the upper right hand corner. What version number do you see there? The latest release is 5.3.0[4], and if the H9 was updated correctly, that is what you should see.
If you do in fact see that number there, could you please take a screenshot of the error message you are seeing when you try to load SpaceTime.
