Home Forums Products Stompboxes No audio output when switching from bypass to active. Reply To: No audio output when switching from bypass to active.
#142517
Gav RL
I think this happened to me tonight too, so suspect it’s an actual firmware issues buried deep somewhere. Loaded a preset via Ableton, with it loading up with the H9 engaged. If at any point I bypass it, when I next try to turn it on, it mutes the whole lot. Turn it off again, signal returns, minus the H9, obviously. Had to turn the power off and on again to get it to stop doing it.
