Home › Forums › Products › Rackmount › 724 Reich Loops › Reply To: 724 Reich Loops
February 19, 2016 at 10:17 pm
#142640
It looks as though you can use an expression/volume pedal to control the input level to the loop.
You don't have to use a pedal here – it is just a convenience for performance use. Otherwise you could use any other means to control this volume as you prefer.
If you want to use a pedal, plug it into the pedal jack on the back of the H8000.
