Home › Forums › Products › Rackmount › orville missing banks › Reply To: orville missing banks
February 25, 2016 at 3:37 pm
#142671
I think I would suggest that you re-initialize the unit (see UM for info). This will fix the checksum problem. If it comes back, you should change the battery and re-init again.
The banks issue may be related to the above, or it could be a bad flash memory chip.
The problem with the wheel – who knows ! This is getting to be an old machine. The above may fix it.
