Home › Forums › Products › Plug-Ins › The #102 Dual Shift Algorithm in H3000 Factory native › Reply To: The #102 Dual Shift Algorithm in H3000 Factory native
March 16, 2016 at 2:37 pm
#142889
Hi teacue-
Yes, the modules you mention in the plug-in do correspond to the parameters in the H3000 hardware algorithm, though we can't guarantee it will sound exactly the same (I believe it should be close). You should be able to therefore recreate the presets based on that algorithm. I will have to check if we have records of the original preset parameter values from the H3000, since that's a bit of an archaeological task.
Best,
Tom
