Home › Forums › Products › Rackmount › Configuring H8000FW for dual-stereo using ADAT › Reply To: Configuring H8000FW for dual-stereo using ADAT
March 18, 2016 at 6:38 am
#142901
ThreeFingersOfLove
Nick,
I need to pester you again about this. From the Routing app I use preset 12 ADAT A-B. At 96 KHz, sending two channels (a stereo signal) of ADAT occupy channels 1, 2, 5, 6 on the H8000-FW. The second stereo channel (again at 96 KHz) occupy channels 3, 4, 7, 8. Is this normal?
Does the same hold true for ADAT outputs, i.e. the first stereo ADAT output channels occupies 1, 2, 5, 6 and the second 3, 4, 7, 8??
Thanks
