Home › Forums › Products › Stompboxes › Crosstalk / Feedback Issue › Reply To: Crosstalk / Feedback Issue
#142970
avalanchis
    wedelich wrote:
    Your understanding is correct.  If the H9 is in Pre/Post mode and your preset is set and saved at Pre, H9 i/o 2 should pass the signal unchanged.  A few questions to get started:
    1. Is your amp’s loop serial or parallel?
    2. Does this occur with any other algorithms on H9, or is it exclusive to Phaser?
    3. Is the feedback a quick burst, or is it just constant once you engage your loop?
    1.  Serial I think.  I have an email in to Atomic support to confirm.
    2.  Seems to happen with all algorithms.  Tried it with a bunch of different factory presets.
    3.  Feedback is constant.  I will try to record some samples and post them here.
