Home Forums Products Stompboxes H9 midi bypass Reply To: H9 midi bypass
#142979
voodoojeff
Hey GKellum, that spawns a question I`ve been pondering: is there a way to have the H9 react to a second midi command differently? Perhaps the application will explain th equestion better:
Let`s say I`m using whatever midi controller that has ten buttons to change presets on the H9. I`m on preset 3, and step on the button for preset 7. Preset 7 comes on. Is it possible to program the H9 to toggle active/bypass by stepping on the same button again? Basically getting the H9 to react differently to the same midi command a second time ie; it knows it`s already ON preset “X”, so it knows you want it to toggle.
Perhaps it`s simply a way to overcomplicate a solution I don`t even really need, but there have been an instance or two where it would be convenient.
