Home › Forums › Products › Stompboxes › H9 Quadravox and Diatonic Pitch Problem › Reply To: H9 Quadravox and Diatonic Pitch Problem
March 25, 2016 at 10:09 pm
#142988
just a shot in the dark, but check the internal routing settings. If it`s somehow on wet/dry you may sending that signal to the side of the H9 that isn`t plugged in (assuming you`re only using one of the outputs).
