Home › Forums › Products › Stompboxes › Pitchfactor midi help › Reply To: Pitchfactor midi help
March 29, 2016 at 5:20 pm
#143035
gkellum
If you have the latest firmware installed on your PitchFactor, you can use it together with H9 Control, which should make a lot of the configuration self explanatory. If you connect it to H9 Control, click on the Pedal button in the apps bottom menubar, and go to MIDI Settings, you'll see that most of PitchFactor's MIDI functionality can be configured there.
