Home › Forums › Products › Plug-Ins › Ultrareverb issue buss/insert option missing › Reply To: Ultrareverb issue buss/insert option missing
April 4, 2016 at 3:37 pm
#143100
Hi Jack-
We removed the Buss/Insert categories, since UltraReverb now has the "Mix Lock" control. By turning "Mix Lock" on, when you load presets the Mix value stays the same between preset changes. So for example, if you have UltraReverb on a Buss, set the Mix to 100% and turn "Mix Lock" on, and then select presets as you would before.
We figured this would be a cleaner approach, since it removes the need to have two sets of presets that are entirely identical except for the Mix value.
Best,
Tom
