Home › Forums › Products › Plug-Ins › The #102 Dual Shift Algorithm in H3000 Factory native › Reply To: The #102 Dual Shift Algorithm in H3000 Factory native
Does H3000 Factory Native contains all the parameters of the H3000 Hardware Algorithm #102 Dual Shift?
I am slowly and enthusiastically learning how to program the H3000 Factory Plugin ![]()
For this purpose I had a look to the Eventide H3000 Programming Worksheets that one can find on your old site.
In these Workseets I founded the parameters for the algorithm #102, Dual Shift:
Left Pitch
Left Delay
Left Feedback
Left Mix
Right Pitch
Right Delay
Right Feedback
Right Mix
And the Expert Parameters:
Low Note
High Note
Source
Seing that you could reproduce the preset #102 Dual Shift in the Plugin,
can I consider that the parameters Left Pitch, Left Delay, Left Feedback and Left Mix from the the Dual Shift algorithm are similar to:
Pitch Shift 1, Delay 1, Delay 1 Feedback and Mixer 1 in the Plugin?
(Then the same for right)
And that the expert parameters Low Note, High Note are similar to:
Pitch Shift Parameters: Low Note, High Note in the plugin?
If yes, it would mean that all the H3000 original presets based on this algorithm (to my knowledge there are twenty presets) can be reproduced in the plugin.
Would you then consider to provide the Data Sheets of these original presets?
In my learning process I would gladly reproduce/transcribe these presets manually.
Best regards
Intersting question. I’ll try re-creating one of the H3000 Dual shit algo presets and compare the sound 🙂
