Home Forums Products Rackmount H8000FW – FireWire (clock source disabled) and Word Clock Reply To: H8000FW – FireWire (clock source disabled) and Word Clock
#143120
    Largely correct, except:
    1) Typically, you set things up once, and don't change them often, so it is not really an issue.
    2) The H8000 will remember its settings.
    3) Some DAWs will be able to launch the Control Panel, so you can do it without another App.
    4) If you hate the Control Panel, you can use the H8000 front panel when the computer is off.
