Home Forums Products Stompboxes TIMEFACTOR Modulation Delay – Modulation Type Question Reply To: TIMEFACTOR Modulation Delay – Modulation Type Question
#143364
llemtt
javiceres wrote:
BTW, serial routing in TF delays would allow the effect described above.
Yes as you say it “would” but it’s not exactly sufficient because actually you can’t modulate just one of the two delay lines, and maybe without a parallel fx loop you’ll need also a “global” parallel dry path.
Serial routing would be a wonderful addition in his own but at best you’ll end up with a “modulated delay” followed by a TZF…
cheers
