Home › Forums › Products › Stompboxes › H9 transmitting midi clock with presets question › Reply To: H9 transmitting midi clock with presets question
May 20, 2016 at 3:10 pm
#143403
nickrose wrote:
As stated above, we believe this problem was fixed long ago in V4.8.0.
If you still see it, please say what version of (stompbox) software you are using.
Thank you for your fast answer. You are right, now it works! =)
It was my fault, because I didn´t save the Preset at the H9 itself. I just tapped in a new tempo and then stored the preset with my Disaster Area Controller. When I recalled the preset the tempo was false. So I experimented a little bit and discovered finally that I have to of course at first save the preset to the H9.
Now it works! 🙂
All the best,
Garfield
