Home › Forums › Products › Stompboxes › Using Midi and Aux switch in conjunction › Reply To: Using Midi and Aux switch in conjunction
May 20, 2016 at 10:22 pm
#143409
holhas556
Thanks for resonding so quickly!
No need to order a trs y split cable then. I will use the aux switch to go through banks and then use the buttons on the eventides to turn the presets on and off.
