Home Forums Products Stompboxes H9 – Midi CC to control Set parameters? Reply To: H9 – Midi CC to control Set parameters?
#143522
gkellum
harmamusic wrote:
Does the Mix correspond with Set Parameter 1? Default this is CC #22.
Yes, the Mix corresponds to Parameter 1 and it defaults to MIDI CC 22.  If you look at the algorithm UI in H9 Control parameters 1 – 6 are the top row of parameters going from left to right and parameters 7 – 19 are the bottom row of parameters going from left to right.
