Home Forums Products Stompboxes H9 Expression Pedal Help Needed Reply To: H9 Expression Pedal Help Needed
#143560
gkellum
nosidamde wrote:
is how can I use an expression/volume pedal as both an expression/volume pedal with the H9?
Well, if you look under the More menu in H9 Control there are buttons there for making an expression act like a volume pedal on a per preset basis.  So, you can have it act as a volume pedal on some presets and as an expression pedal on other presets.
There's not really a mechanism for having it act as a volume pedal and expression pedal at the same time.  I'm not sure if this is what you were actually asking for though.
