Home › Forums › Products › Plug-Ins › UltraReverb 2.2.2 doesn’t load VST presets in Cubase Pro 8.5.20 (OSX) › Reply To: UltraReverb 2.2.2 doesn’t load VST presets in Cubase Pro 8.5.20 (OSX)
#144319
tlongabaugh
    Hi nkf-
    Ah, I see. I will have to look into the issue a bit more to be sure, but my guess is this: We added a "Mix Lock" parameter to UltraReverb between versions 2.0.11 and 2.2.2, and it's possible that Cubase stores presets by indexing parameters – which means adding parameters would throw it off. My suggestion would be to save your presets using the internal preset system, if at all possible. When I get the chance, I'll investigate this further.
    Best,
    Tom
