Home Forums Products Stompboxes Pitchfactor MIDI pass through and amp change commands Reply To: Pitchfactor MIDI pass through and amp change commands
#145375
Presumably you have the PF MIDI out set to THRU.
With the current version there are occasional issues where THRU can corrupt the MIDI, particularly during program loading. This may be what you are seeing, and will be fixed in the next release.
