Home Forums Products Stompboxes Omnipressor algo for H9 Reply To: Omnipressor algo for H9
#145503
    Here are a few presets to get you started:  a fast, abrupt gate, a rounder gating action, and a Slow Gear-type effect.  Like any compressor, the THRESHOLD setting is critical.  It needs to be carefully adjusted to your input / playing technique, and it is interactive with the rest of the main compression parameters.
    The reverb section isn’t used anywhere here.  MIX settings less than 100% lend themselves to parallel compression effects.  Of course, the distortion algorithms and EQ Compressor can take over the ‘workhorse’ compression chores – in a ‘program dependent’ manner.  Just drop out (or minimize) the drive components.
