Home Forums Products Stompboxes Expression pedal problem with H9 – 0 to 86 to 0?! Reply To: Expression pedal problem with H9 – 0 to 86 to 0?!
#146531
jatomk
As I observe similar issue with my setup let me post my question here.
Issue is tha values controled by expression jumps from min to max, nothing in-between.
My setup is as follows:
Boss FV500H expression to Boss ES-8 switching sysem via TRS cable. ES-8 to Eventide H9 via MIDI cable. All programmin n ES-8 is done correcty according to Boss knowledge base instruction.
Additional issues are very slow response – even jump between min max value is not instand and latency is significant, and after changing programm it is required to move pedal back and forth in order to make it “visible” for H9 and I thing H9 should read current position of the pedal after programm change.
I believe that there is one solution to fix all listedmalfunctons
thanks in advance
Tomek
