Home › Forums › Products › Rackmount › Eclipse + H9 tap tempo with groundcontrol › Reply To: Eclipse + H9 tap tempo with groundcontrol
June 4, 2017 at 8:00 pm
#146578
yes, you did, thank you. But I’m not sure, I’m doing everything right.
I assigned a momentary switch on my controller with cc13. On the Eclipse under Tempo, I assigned it to ext1.
But I’m puzzled what I need to put it exactly on Ext1. General? Midi? And what exactly in the relevant tabs then? Can’t seen to find that in the manual at all.
