Home › Forums › Products › Stompboxes › How to turn ON/OFF 2 eventide stompboxes connected by MIDI (timefactor as master and space as a slave)?? › Reply To: How to turn ON/OFF 2 eventide stompboxes connected by MIDI (timefactor as master and space as a slave)??
#148105
4_cuerdas
    nickrose wrote:
    Sorry – can’t be done as you describe. Assuming that by “off” you mean bypass, the problem is that when you bypass one unit, it does not send a MIDI message saying that this happened.
    You probably need some kind of pedalboard to achieve this.
    Hi Nick, and thanks for your reply.
    Yes I meant bypass. I use a digitech 3 button switch pedal with my Eventide stompboxes. I use it to activate the “infinite delay” in the Timefactor, to switch bank down (on both units) and to tap tempo. Is it possible to use one of the button-switches of my ext switch pedal to bypass both units?
    Cheers
