Home › Forums › Products › Rackmount › Configuring H8000FW for dual-stereo using ADAT › Reply To: Configuring H8000FW for dual-stereo using ADAT
May 1, 2018 at 8:13 pm
#149098
just to be clear, the dual stero setup works fine at 48k. It should be as simple as changing the clock rate and the H8000 simply adapts as necessary to make it work.
Another aside here…. if I have the H8000 kooed up and runnign at 48k, when i change the external clock rate to 96k, the h8000 crashes (tells me to power down)
