Home Forums Products Stompboxes Max For Live H9 Remote plugin released – supports automation of H9 using CC Reply To: Max For Live H9 Remote plugin released – supports automation of H9 using CC
#149234
peterfrequency
    Thanks for the quick reply. Good tip about just using different channels. In any case I think it should be fine because they are still sequential – from memory I just shifted the CC numbers 20 or 30 higher so as to avoid overlap.
    Push support is very appreciated too. Thanks again!
