Home › Forums › Products › Stompboxes › Strange mix behaviour › Reply To: Strange mix behaviour
#149465
gcrooks
    I was having the same issue. I’m glad I read this. I did not know that “global mix” on would transfer the mix from the previous patch. How is that “global?” Anyway because I am using an expression pedal and have it set to “mix” on another patch apparently that is why the mix settings were going to zero and would not save. Global set to off, seems to have fixed the problem.
