Home Forums Products Stompboxes Parallel FX Set Up: kill dry = yes but dry signal present Reply To: Parallel FX Set Up: kill dry = yes but dry signal present
#149733
bohan
oggietel wrote:
I have my clean signal and I want to blend that with my FX pedals using a Xotic stereo blender. Consequently, I want only 100% wet from the FX (0% dry) so as to avoid phasing issues and increased volume (which happens if 2 of the same clean signals are combined in phase, which I currently have). Surely that's a parallel FX set up???
OK. I thought you were trying to use it with an amp. Yeah, that's a parallel setup.
Here is the thing:
Killdry will only kill the dry signal in the DSP processor. So if your Bypass Mode is set to Relay, you will hear the dry signal when your pedal is bypassed because the input is connected to the output directly. If you set the Bypass Mode to DSP or DSP + FX, you won't hear the dry signal when your pedal is bypassed (aka. bypass enabled).
