Home Forums Products Stompboxes Organising presets on multiple H9’s Reply To: Organising presets on multiple H9’s
#149903
bohan
    mistercharlie wrote:
    What would be really cool would be a way to use MIDI to swap currently-active presets. Then you could quickly switch, say, pitch shift before dirt, to pitch shift after dirt.
    Of course, you can do that. Basically, you need to set up your presets beforehand. Say you have two preset lists on your two H9s:
    First H9: 1.Pitch 2.Dirt  3…4…5…99
    Second H9: 1.Dirt 2.Pitch   3…4…5…99
    Then you can connect your MIDI controller to the first H9, and connect your first H9's MIDI OUT to your second H9's MIDI IN. Then you should be able to switch to any pair of presets together by sending one MIDI PC message from your MIDI controller.
