Home › Forums › Products › Stompboxes › The new HotSawz algorithm is available for the H9 now! › Reply To: The new HotSawz algorithm is available for the H9 now!
November 30, 2018 at 10:08 pm
#150724
gkellum
jbradwilson wrote:
Finally figured out the issue of no sound from the Hotsawz algorithms. I was connecting the H9 to the effects loop of a Headrush pedalboard with 4 cables; 2 sends and 2 receives. The loop was not set for a stereo send. Even though every other algorithm worked, Hotsawz would not until I set the send as stereo. I also found I could disconnect one of the sends and make it work in mono, but if both send cables are connected both sends must have signal.
Oh, wow, that's interesting. Thanks for letting us know. That's surprising.
