Home › Forums › Products › Rackmount › H3000D-SE that sounds “thin”.. › Reply To: H3000D-SE that sounds “thin”..
December 2, 2018 at 11:40 pm
#150732
Foster
skywriter wrote:
I dont use plugins, only hardware. My H3000-D/SE doesn’t sound overly bright 50-100% mix. If it hasn’t been done, I would suggest listening to a 50/50 mix directly out of the H3000 without recombining with the original signal. Then there won’t be any phasing issues with the sound. If it sounds fuller, then suspect a phasing issue somewhere.
Tomorrow I’ll do this test too, thank you for your suggestion!
Foster
