Home › Forums › Products › Stompboxes › Hot Sawz best practice › Reply To: Hot Sawz best practice
December 6, 2018 at 3:56 pm
#150762
I can’t help you with the loop end, but I’m finding HotSawz anything but thin on the front end. Quite the opposite, with extreme filter settings. I do run in stereo, yet I don’t see anything internal to the algo that might cause phase cancellation in mono. Maybe the detuned oscillators … but I don’t think so.
Without much modulation going on, a low MIX and/or CUTOFF below 50 or so really damps things down. I’m finding them to be fairly interactive together. HotSawz is dynamic to to input level, so I might check there second. Compression might help, but I’d tend to think on the output, to preserve input triggering.
