Home › Forums › Products › Rackmount › h9000 toggle switch suggestion › Reply To: h9000 toggle switch suggestion
Let me start by saying I generally love the UI on the H9k. Very easy to get around, allows me to find and directly edit the parameters I care about; all good.
I do have a suggestion for the parameters you are representing with a toggle switch (mono/stereo, fast/slow, etc). Right now, I arrow over to the parameter and turn the data wheel. Currently a menu pops up and makes me stop and read it and then twist the wheel to select what I want. that's kind of slow and distracting.
Why not have the text under the toggle switch change directly when I turn the data wheel like virtually every other parameter? That's seems faster and more in-line with how the rest of the UI operates. Also allow the up/down arrows on the keypad to change the value too.
You're right, the toggle switch doesn't need a popup list – we should probably change that.
However, you can also just toggle the switch by hitting the Enter (check) key instead of using the wheel.
