Home › Forums › Products › Rackmount › H9000 – Algorithm Guide › Reply To: H9000 – Algorithm Guide
December 19, 2018 at 11:15 pm
#150852
There is a significant difference between the Eclipse and the H9000.
The Eclipse has a small number of algorithms (maybe 100 ?), and then presets based on those algorithms.
The H9000 follows the H8000 model, where each preset is an algorithm (admittedly, some are clones). There are over 1000 such presets.
This means that the amount of work involved in documenting the H9000 algorithms to the level of detail offfered by the Eclipse is likely beyond us, especially when you consider that the H9000 is by definition a low volume product.
