Home › Forums › Products › Rackmount › H8000FW – PCMCIA / SD Card Adapter ?? › Reply To: H8000FW – PCMCIA / SD Card Adapter ??
December 21, 2018 at 2:47 pm
#150860
An SD adaptor will probably not work because the SD card is serial while the CF card is parallel. Presumably an adaptor might do the parallel to serial conversion, but I wouldn't want to assume this.
The 16G might be a problem also.
I would suggest an adaptor and a CF card, while they are still available.
