Home Forums Products Rackmount H8000FW – PCMCIA / SD Card Adapter ?? Reply To: H8000FW – PCMCIA / SD Card Adapter ??
#150861
xmrr
nickrose wrote:
An SD adaptor will probably not work because the SD card is serial while the CF card is parallel. Presumably an adaptor might do the parallel to serial conversion, but I wouldn’t want to assume this.
The 16G might be a problem also.
I would suggest an adaptor and a CF card, while they are still available.
Yeah i was thinking something along those lines.
Do you think it would work with a 2~16gb CF card or it should be less than 2?
Thanks
